Re: Bulkhead Question
Posted by Paul Konish on Jul 6, 2004
Irv, I had a similar problem when I built my CH17. I added a piece of 4 mm plywood to the bulkhead from the sealed compartment side to cover the gap. If you feather the bottom edge it looks ok and no one will see it anyway. Use the planning gauge to get the radius and then trim it to fit. Then I fill the gap with thickened epoxy from the cockpit side.
In Response to: Bulkhead Question by Irv Kooris on Jul 6, 2004
- Re: Bulkhead Question by Irv Kooris on Jul 6, 2004
- Re: Bulkhead Question by Howard on Jul 7, 2004
