Re: Your are in for it...
Posted by SB on Jun 29, 2004
another tip is to use multiple straps and put some stringers on the deck along the edge to take the pressure of the straps. This helps to displace the pressure evenly across the deck so that you do not get the ripple effect where the straps are placed.
As anytime you clamp something, evenly distributing the pressure is key. I used some pine scraps that were left over from the sheerclamps and laid them out just out side the straps. then started to tighten up as I went along.
In Response to: Your are in for it.... by Homer on Jun 28, 2004
- Re: Your are in for it... by Dave Matthews on Jul 1, 2004
- Re: Your are in for it... by Laszlo on Jul 8, 2004
