Re: Fixed Hole
Posted by Jay E. Morris on Jun 28, 2004
From what I've read on people using the magnet flush hatches it sounds as if they're as much if not more secure than straps. 8x6lb pull = 40lbs of pull. Some have had to cut a slot in one corner to be able to pry the lid off. Unless you're spinning like a washing machine with a can of beans loose in the hold, I don't see a problem.
In Response to: Re: Fixed Hole by Laszlo on Jun 28, 2004
- Re: Fixed Hole by FrankP on Jun 28, 2004
- Re: Fixed Hole by Jay E. Morris on Jun 28, 2004
