Re: Bizarro....
Posted by Laszlo on Jun 27, 2004
George,
That's a good point, but can be addressed by always brushing some unthickened epoxy on both pieces in a joint before putting on the glue. If it's end grain, I let it soak in a bit then add some more, then add the glue. Never had a starved joint since I started doing this.
Also, inside corners are stress concentrators, so I avoid them whenever I can. Anytime one exists, I fillet it.
This has probably caused more discussion than it should have. The extra weight of that tape probably wouldn't matter even to a racer. I was just puzzled.
In Response to: Bizarro.... by George on Jun 25, 2004
- no way by LeeG on Jul 1, 2004
