Re: Glassing the Deck
Posted by Doug Judd on Jun 25, 2004
Both the instruction manual and CLC video indicate glassing before any other deck work. Simply let the cloth drape across the cockpit opening, and wet it out just like you did the hull. When the epoxy is cured, or even "green", you can use a razor knife to remove the excess cloth over the opening.
Have fun!
In Response to: Re: Glassing the Deck by Jeffrey Ward on Jun 25, 2004
- Re: Glassing the Deck by Dennis Rioux on Jun 25, 2004
