sculling brace/cowboy
Posted by LeeG on May 30, 2004
Some kayaks are easier to empty than others while you're in the water,,go to the stern, put all your weight on the keel popping the bow up in the air and drain the cockpit, twist the kayak over as you fall off and that should have drained out most of the water.
In Response to: Gosh... (long-winded) by Kurt Maurer on May 29, 2004
- Re: sculling brace/cowboy by FrankP on Jun 2, 2004
