Boat Plans |
Supplies |
Sailboats |
Books/DVDs |
Kayaks |
Kayak foot peg install question
Do you need to put fiberglass inside the hull under the metal track, or can you just bolt the track to the hull? I have almost finished painting the hull.
1 reply:
RE: Kayak foot peg install question
» Submitted by twofootartist - Fri, July 3 » 9:37 AM
You can just bolt it on. Depending on the shape of your boat, though, you might consider installing a spacer board between the track and the hull so your feet will more easily fit on the foot pegs.
